I am working to interface just such a serial device and would like to know
where devNode and drvNode can be found.
Rodney Porter
IPNS, Bldg. 360, Rm. C-209
Argonne National Laboratory
9700 South Cass Avenue
Argonne, IL 60439
Tel. (630) 252 - 7151 * Fax (630) 252 - 7766
-----Original Message-----
From: Peregrine M. McGehee [mailto:[email protected]]
Sent: Friday, August 24, 2001 11:32 AM
To: Steven Hartman
Cc: EPICS tech-talk
Subject: Re: devNode, drvNode, drvSerial source?
Steve,
drvSerial is commonly used with drvAscii/devAscii layer that
supports a fairly generic command and response system. An up to date
version can be obtained from Allan Honey at Keck
([email protected]). drvSerial itself provides device
independent support for (named) serial devices.
The devNode/devNode package is a simple layer that uses drvSerial.
It is not nearly as robust as drvAscii/devAscii, although does
handle the case of multiple response delimiters, which drvAscii
does not. Unless you have a very strange device (like the legacy
control system we were talking to for the CFHT application)
I'd recommend use of drvAscii instead.
The tyGsOctal software does not _require_ use of drvNode, or even
drvSerial for that matter.
Steven Hartman wrote:
> Is source code for drvNode, devNode and drvSerial still available?
> I am looking into using Andrew Johnson's drvIpac with tyGSOctal for serial
> communication using SBS IP-OctualUART-232 modules mounted on a SBS VIPC616
> carrier board. It appears that this configuration will also require
> devNode and drvNode and maybe drvSerial?
> The links for devNode and drvNode
> (ftp://ftp.cfht.hawaii.edu/pub/tcs/epics/) are no longer valid.
> Thanks,
> Steve Hartman
> [email protected]
> Duke Free Electron Laser Laboratory
Aloha,
Peregrine
Peregrine M. McGehee [email protected] (505) 667-3273
Spallation Neutron Source - Global Controls (SNS-4)
MS H820, Los Alamos National Laboratory, Los Alamos, NM 87545
- Re: devNode, drvNode, drvSerial source? Peregrine M. McGehee
Re: Problem talking CA across two CPUs in same crate??? Ernest L. Williams Jr.
<2001>
2025
2026
<2001>
2025
2026
