Yes there is a gateway set in the VxWorks boot parameters.
Len
Jeff Hill wrote:
> > Very good thank you much. I set the EPICS_CA_ADDR_LIST variable
> > in VxWorks and the PVs in the sequencer appear to be connecting.
> So this mystery remains: why is the CA broadcast address
> not seen by CPU2, but the CA unicast in your EPICS_CA_ADDR_LIST
> is? I am guessing that your CPU1 is sending all of its traffic
> to a router that is configured to not forward IP packets with
> a broadcast destination address. Type routeShow to see if
> this is the case.
> Perhaps you have the "gateway IP" set in the vxWorks boot
> parameters. This results in an odd route auto-configured by WRS
> that sends all IP packets to the router even if the destination
> is on the attached LAN. This can be fixed by using the routeDelete
> command followed by the routeAdd command.
> Jeff
> > -----Original Message-----
> > From: Leonard J. Reder [mailto:[email protected]]
> > Sent: Friday, August 24, 2001 4:53 PM
> > To: Ernest L. Williams Jr.
> > Cc: EPICS Tech-Talk
> > Subject: Re: Problem talking CA across two CPUs in same crate???
> > Thanks,
> > Len
> > "Ernest L. Williams Jr." wrote:
> > > Hi,
> > > Given that two IOCs need to talk with each other they could each "CA
> > > client" just as your SUN workstation becomes a client.
> > > Now you must define for the IOC the EPICS_CA_ADDR_LIST environment variable.
> > > This could be done in the resource.def file as follows:
> > > # add the following line
> > > EPICS_CA_ADDR_LIST DBF_STRING <IP Address of the IOC you want to
> > > talk to>
> > > OR
> > > you could add a putenv statement in your st.cmd file as follows:
> > > putenv (" EPICS_CA_ADDR_LIST = <IP Address of the IOC you want to talk to>
> > > Hope this helps.
> > > Thanks,
> > > SNS Control Systems Group, ORNL
> > > 701 Scarboro Rd., MS 6473
> > > Oak Ridge, TN 37830
> > > Phone 865-241-9071
> > > e-mail: [email protected]
> > > Fax 865-241-6739
> > > ----- Original Message -----
> > > From: "Leonard J. Reder" <[email protected]>
> > > To: "EPICS Tech-Talk" <[email protected]>
> > > Sent: Friday, August 24, 2001 12:41 PM
> > > Subject: Problem talking CA across two CPUs in same crate???
> > > > Hello,
> > > > I am using EPICS R3.13.3 and I am using the sequencer. There are
> > > > two Motorola PPC boards in my configuration. One of which has
> > > > a sequencer within it (call it CPU1) and the other has PMAC
> > > > motor control (call it CPU2). It appears that the sequencer
> > > > works fine with recorders within CPU1. But for some reason
> > > > the sequencer process variables that are associated with
> > > > recorders in CPU2 cannot connect. Both CPUs are plugged into
> > > > the same network also.
> > > > Are there any ideas what could be wrong with my configuration.
> > > > Oh yes I can get to all the process variables via the client
> > > > Sun workstation using caget, caput and camonitor calls.
> > > > All replies would be greatly appreciated.
> > > > Len
> > > > ____________________________________________________
> > > > Leonard J. Reder
> > > > Jet Propulsion Laboratory
> > > > Interferometry Systems and Technology Section 383
> > > > Email: [email protected]
> > > > Phone (Voice): 818-354-3639
> > Leonard J. Reder
Leonard J. Reder
- RE: Problem talking CA across two CPUs in same crate??? Jeff Hill
Re: Problem talking CA across two CPUs in same crate??? Andrew Johnson
<2001>
2025
2026
RE: Problem talking CA across two CPUs in same crate??? Mark Rivers
<2001>
2025
2026
