1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem talking CA across two CPUs in same crate???
To: "Leonard J. Reder" <[email protected]>
Cc: "EPICS-tech-talk" <[email protected]>
Date: Fri, 24 Aug 2001 18:45:48 -0600
Assuming that your router is at a.b.c.e then add the following to
the top of your startup script to eliminate the route created
by the gateway entry in the boot parameters.
routeDelete ( "a.b.c.0", "a.b.c.e" );
routeAdd ( "a.b.0.0", "a.b.c.e" );
This will allow communication with any host on network a.b.x.x.
You can be more specific about what you will allow by using
several routeAdd commands specifying only the subnets that
you will communicate with. For example this will allow communication
only with subnet a.b.10.x a.b.11.x.
routeAdd ( "a.b.10.0", "a.b.c.e" );
routeAdd ( "a.b.11.0", "a.b.c.e" );
Or if you don't want to allow any off-subnet communication then
perform the routeDelete() and don't bother with the routeAdd
above.
Jeff
Prev: Re: Problem talking CA across two CPUs in same crate??? Leonard J. Reder
Next: portable ca server john sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem talking CA across two CPUs in same crate??? Andrew Johnson
Next: mbboDirectRecord changes (3.13.4 vs 3.13.[1,2]) Brian McAllister
