1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: mbboDirectRecord changes (3.13.4 vs 3.13.[1,2])
To: [email protected]
Cc: [email protected]
Date: Fri, 24 Aug 2001 17:45:04 -0400
Who re-wrote the mbboDirectRecord between 3.13.2 and 3.13.4, and what was
the purpose of the changes to process() ?
There seems to be some very confusing behavior the first time you write to
VAL if the record has never been processed.  Why does it reset VAL from the
B* fields, overwriting the value I wrote to it ?
I could return status=2 from init_mbboDirect() and leave UDF=True, which
will make it skip the "reset from B*" step, but that also bypasses the call
to convert() and RVAL won't be set properly when writeValue() is called.
The simplest solution I can see is to set SEVR=NO_ALARM in my device
support init_mbboDirect() routine, which seems very wrong.
Am I missing something obvious ?
Am I the only one who wants to use this to manipulate groups of bits,
rather than collecting a set of individual ones ? With the old version, you
could ignore the B* fields.  Now you can't.
Brian McAllister                    Controls Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
Prev: Re: devNode, drvNode, drvSerial source? Peregrine M. McGehee
Next: Re: Problem talking CA across two CPUs in same crate??? Leonard J. Reder
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problem talking CA across two CPUs in same crate??? Jeff Hill
Next: portable ca server john sinclair
