Very good thank you much. I set the EPICS_CA_ADDR_LIST variable
in VxWorks and the PVs in the sequencer appear to be connecting.
Len
"Ernest L. Williams Jr." wrote:
> Hi,
> Given that two IOCs need to talk with each other they could each "CA
> client" just as your SUN workstation becomes a client.
> Now you must define for the IOC the EPICS_CA_ADDR_LIST environment variable.
> This could be done in the resource.def file as follows:
> # add the following line
> EPICS_CA_ADDR_LIST DBF_STRING <IP Address of the IOC you want to
> talk to>
> OR
> you could add a putenv statement in your st.cmd file as follows:
> putenv (" EPICS_CA_ADDR_LIST = <IP Address of the IOC you want to talk to>
> Hope this helps.
> Thanks,
> SNS Control Systems Group, ORNL
> 701 Scarboro Rd., MS 6473
> Oak Ridge, TN 37830
> Phone 865-241-9071
> e-mail: [email protected]
> Fax 865-241-6739
> From: "Leonard J. Reder" <[email protected]>
> To: "EPICS Tech-Talk" <[email protected]>
> Sent: Friday, August 24, 2001 12:41 PM
> Subject: Problem talking CA across two CPUs in same crate???
> > Hello,
> > I am using EPICS R3.13.3 and I am using the sequencer. There are
> > two Motorola PPC boards in my configuration. One of which has
> > a sequencer within it (call it CPU1) and the other has PMAC
> > motor control (call it CPU2). It appears that the sequencer
> > works fine with recorders within CPU1. But for some reason
> > the sequencer process variables that are associated with
> > recorders in CPU2 cannot connect. Both CPUs are plugged into
> > the same network also.
> > Are there any ideas what could be wrong with my configuration.
> > Oh yes I can get to all the process variables via the client
> > Sun workstation using caget, caput and camonitor calls.
> > All replies would be greatly appreciated.
> > Len
> > ____________________________________________________
> > Leonard J. Reder
> > Jet Propulsion Laboratory
> > Interferometry Systems and Technology Section 383
> > Email: [email protected]
> > Phone (Voice): 818-354-3639
Leonard J. Reder
- RE: Problem talking CA across two CPUs in same crate??? Jeff Hill
- Problem talking CA across two CPUs in same crate??? Leonard J. Reder
- Re: Problem talking CA across two CPUs in same crate??? Ernest L. Williams Jr.
mbboDirectRecord changes (3.13.4 vs 3.13.[1,2]) Brian McAllister
<2001>
2025
2026
<2001>
2025
2026
