1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Image capture
To: Jeff Hill <[email protected]>
Cc: Rolf Keitel <[email protected]>, EPICS-tech-talk <[email protected]>
Date: Mon, 03 Sep 2001 15:14:47 +0900
Jeff Hill wrote:
> Rolph,
> > What solutions are currently used in the community for image capture. We
> > want to look at beam spots on scintillators with a camera and integrate
> > capture and maybe processing into the control system.
> On a related note, I have finished a CA protocol upgrade that includes
> a configurable maximum array size limit. This will show up in the next
> R3.14 release.
> Jeff
When you consider to extend CA libarary to support large array, please also
consider to add API/protocol to access subarray with offset.
As far as I understand, EPICS CA/DB library allow to access a part of
array if it starts
from the top of array, ie. a[:n] in Python notation.. In Db library, we
needed to implement
API to access array data with offset, i.e. a[n:n+m] in Python notation
again, for effcient use
of memory in a subarray record.   I believe this kind of access method
is useful for many applications and it will not so difficult and will
not break any existing application.
I would greatly appriciate if you could consider this possibility.
Thank you,
Noboru Yamamoto
KEKB control group
KEK, JAPAN
RE: Image capture Jeff Hill
Prev: Re: alarm handler confusion (and solution) Janet Anderson
Next: RE: Image capture Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Image capture Jeff Hill
