Update to shared libraries build bug:
The bug in the config/RULES.Host file of EPICS base did not stop
builds of shared libraries for base releases R3.13.3 and R3.13.4.
This bug shows up only in base releases R3.13.5 and R3.14.0.alpha2.
In these releases DLL_LIBS is defined in CONFIG.Host.UnixCommon. In
the earlier releases, DLL_LIBS and DLL_DEPLIBS were only defined for
WIN32 and Borland hosts.
For R3.14.0.alpha2 this bug will stop shared libraries builds only
when building a R3.13 extension or application with R3.14.0.alpha2
base.
The bug fix remains the same.
Bug fix: Remove the following lines from config/RULES.Host
ifneq ($(words $(DLL_LIBS)), $(words $(DLL_DEPLIBS)))
# If invalid library names, don't make DLL file
SHARED_LIBRARIES = NO
endif
Janet
- shared libraries build bug Janet Anderson
serial stuff on r3.14 Allan Honey
mvme162PA-344SE and mvme162-532A Dale L. Brewe
<2001>
2025
2026
3.14 on Linux Ian A Smith
<2001>
2025
2026
