1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS R3.13.4 Build question???
To: "Leonard J. Reder" <[email protected]>
Cc: "EPICS-tech-talk" <[email protected]>
Date: Fri, 19 Oct 2001 11:54:01 -0600
Len,
Perhaps the problem is that R3.13.4 will not work correctly with
Tornado I if the SENS IP kernel is installed. I believe that
R3.13.4 is used routinely with Tornado II (SENS IP kernel is always
used there) and with Tornado I without the SENS IP kernel.
This would point to my ifdef checking the version of the
BSD macro not being a good indication of whether SENS is
installed or not. This might be testing the version of the
vxWorks kernel only and not whether SENS is installed.
Open to suggestions for a better test.
The problem with this theory is that I dont see that the
message "CAC: SIOCGIFCONF ioctl failed because 6" would be
occurring either in Tornado I or in Tornado I with the SENS
IP kernel unless this early version of the SENS IP kernel
has a problem with the SIOCGIFCONF ioctl. Problems with
the BSD macro based version macro should exhibit different
symptoms.
Jeff
> -----Original Message-----
> From: Leonard J. Reder [mailto:[email protected]]
> Sent: Friday, October 19, 2001 11:33 AM
> To: Jeff Hill
> Cc: EPICS Tech-Talk
> Subject: Re: EPICS R3.13.4 Build question???
> Thanks very much Jeff....
> I think the problem is with our new Tornado 1 installation.
> It seems that EPICS R.3.13.3 when rebuilt gives the same
> errors.  When built with our old install it works fine.
> Since we are upgrading to Tornado 2 in January I think
> I will shelve this for now but may need to trace it in
> the future.
> Thanks for you response it was very very helpful.
> Len
> Jeff Hill wrote:
> > Leonard,
> > It would appear that ioctl(SIOCGIFCONF) returns errno six on your
> > system. This indicates "No such device or address". There are some
> > subtle difference in this io control between the IP kernels in Tornado
> > I and in Tornado II, but the call should be initially successful on
> > both OS. So I am confused. What do you see when you type ifShow on
> > your system? Is there any possibility that EPICS was built against
> > Tornado II header files and then loaded into a Tornado I system?
> > I have not tried this. Perhaps there would be undefined symbols.
> > A quick look at the source does not indicate why your shell is hanging.
> > The "exit" in the output below is probably a clue, but I don't see any
> > code that prints this message in R3.13. If you typed "exit" at a shell
> > prompt a hung ( non-existent ) shell would certainly result.
> > Otherwise to help us track down the hang please use "sp iocInit" instead
> > of "iocInit", and then use tt <task id> on the resulting task to
> > see where it is hanging. Usually the first task spawned with "sp" has
> > name t1 and so you can alternatively type "tt t1". Please e-mail the output
> > from tt.
> > Thanks
> > Jeff
> > > Sent: Thursday, October 18, 2001 4:15 PM
> > > To: EPICS Tech-Talk
> > > Subject: EPICS R3.13.4 Build question???
> > > Hello,
> > > I was using R3.13.3 but with our systems upgrade to Solaris 2.8
> > > I decided to build R3.13.4.  It seemed build fine! with Tornado 1
> > > tools.  I have to use Tornado 1 for now.  I am seeing the following
> > > error messages after the iocInit is executed and then the VxWorks
> > > shell hangs.  Does anyone have any ideas about this problem or how
> > > I can fix it?
> > > Thanks,
> > > Len
> > > SCREEN DUMP STARTS:
> > > sysClkRateSet( 200 )
> > > value = 0 = 0x0
> > > iocInit
> > > St###  arting iocInit
> > > @(#)EPICS IOC CORE built on Oct 15 2001
> > > ###  @(#)Version R3.13.4 $2000/12/15 15:52:33$
> > > Failed to set clock from Unix server
> > > value = 0 = 0x0
> > > exit
> > > iocInit: All initialization complete
> > > osiSockDiscoverInterfaces(): unable to fetch network interface
> > > configuration
> > > Done executing startup script
> > > /home/keck/reder/kroot/kss/if/to/startup/O.mv2304/dsmTest
> > > ____________________________________________________
> > > Leonard J. Reder
> > > Jet Propulsion Laboratory
> > > Interferometry Systems and Technology Section 383
> > > Email: [email protected]
> > > Phone (Voice): 818-354-3639
> Leonard J. Reder
Re: EPICS R3.13.4 Build question??? Leonard J. Reder
Prev: Re: EPICS R3.13.4 Build question??? Leonard J. Reder
Next: porting record to 3.13.4 Pedro Gigoux
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
