1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: porting record to 3.13.4 (part 2)
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 23 Oct 2001 18:14:29 -0300
Hi
First of all thanks for the suggestions I got regarding my previous
question. I got the code compiled with no errors and I'm now in the
process of downloading the ported system to a crate for testing. At this
point I got the following errors:
dbLoadRecords "./data/ecs.db"
filename="../dbStaticRun.c" line number=667
Missing SizeOffset Routine - No record support?
_ecsMotorRecordSizeOffset
0xf4f008 (tShell): memPartFree: invalid block 0x734d in partition
0xbd288.
0xf4f008 (tShell): memPartFree: invalid block 0x14fbc in partition
0xbd288.
0xf4f008 (tShell): memPartFree: invalid block 0x7930 in partition
0xbd288.
Cannot set field FLNK to ec:domeMotorFan.VAL  ((null))
Cannot set field DSTL to ec:domeC.IVAL .PP.NMS ((null))
Cannot set field MSGL to ec:domeC.IMSS .NPP.NMS ((null))
Cannot set field DBGL to ec:debugM ((null))
Cannot set field SIML to ec:simulateL ((null))
dbAllocRecord(ecsMotor) record_size =0
What's the function of this SizeOffset routine? I don't seem to find a
reference to it in the source code of other records.
Thank you,
Pedro
Pedro Gigoux wrote:
> Hi,
> I'm porting a record support routine from EPICS 3.12.3 to 3.13.4 and
> found calls to the following routines that are no longer supported:
>         status = recGblPutFastLink (&(pmr->dstl), (void *) pmr,
>                         &(pmr->dsta));
>         status = recGblInitFastInLink (&(pmr->dbgl),(void *) pmr,
>                         DBR_ENUM, "DBUG")
>         status = recGblInitFastOutLink (&(pmr->dstl),(void *) pmr,
>                         DBR_LONG, "DSTA");
> DSTL and DBGL are an output link and input link respectively. Can
> someone give me a hint on what are the routines I'm supposed to use now
> and how the calling sequence should look like?
Re: porting record to 3.13.4 (part 2) Andrew Johnson
porting record to 3.13.4 Pedro Gigoux
Prev: Re: dm2k & NT/X-Win mem leak? Ian A Smith
Next: Re: porting record to 3.13.4 (part 2) Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: porting record to 3.13.4 Marty Kraimer
