1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: porting record to 3.13.4 (part 2)
To: Pedro Gigoux <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 23 Oct 2001 16:35:23 -0500
Pedro Gigoux wrote:
> dbLoadRecords "./data/ecs.db"
> filename="../dbStaticRun.c" line number=667
> Missing SizeOffset Routine - No record support?
> _ecsMotorRecordSizeOffset
> 0xf4f008 (tShell): memPartFree: invalid block 0x734d in partition
> 0xbd288.
> 0xf4f008 (tShell): memPartFree: invalid block 0x14fbc in partition
> 0xbd288.
> 0xf4f008 (tShell): memPartFree: invalid block 0x7930 in partition
> 0xbd288.
> Cannot set field FLNK to ec:domeMotorFan.VAL  ((null))
> Cannot set field DSTL to ec:domeC.IVAL .PP.NMS ((null))
> Cannot set field MSGL to ec:domeC.IMSS .NPP.NMS ((null))
> Cannot set field DBGL to ec:debugM ((null))
> Cannot set field SIML to ec:simulateL ((null))
> dbAllocRecord(ecsMotor) record_size =0
> What's the function of this SizeOffset routine? I don't seem to find a
> reference to it in the source code of other records.
It gets generated automatically in the .h file that is created from your
record.dbd file.  In the record support routine you have to define and
then undefine the macro GEN_SIZE_OFFSET around the #include of that .h
file, for example the following is the relevent part of the aiRecord.c
file:
#define GEN_SIZE_OFFSET
#include "aiRecord.h"
#undef  GEN_SIZE_OFFSET
This causes the routine to be built into your record.o file.  The other
errors may be related to not having that routine defined, I'm not sure.
- Andrew
Perfection is reached, not when there is no longer anything to add,
but when there is no longer anything to take away.
- Antoine de Saint-Exupery
Re: porting record to 3.13.4 (part 2) Pedro Gigoux
porting record to 3.13.4 Pedro Gigoux
Prev: porting record to 3.13.4 (part 2) Pedro Gigoux
Next: Re: embedded linux experiences Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: porting record to 3.13.4 (part 2) Pedro Gigoux
