1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Using a terminal server to catch boot messages
To: bickley <[email protected]>
Cc: [email protected]
Date: Mon, 29 Oct 2001 15:43:05 -0600
At 03:11 PM 29-10-01 -0500, Matthew Bickley wrote:
I have a vague recollection that some labs have used a
terminal server to record the boot messages generated by an
IOC as it boots.  Is there some standard way for doing this,
or is it completely dependent on the choice of server?  I
would like to hear what choices other EPICS sites have made.
UNICAT uses a network serial port hub to connect to the
VxWorks console port.  The serial port is connected
to a Linux device port, such as /dev/ttySI0.
That port can be opened for direct 2-way connection
with the VME for configuration.
Alternatively, the text stream on the serial port can be
time-stamped and logged by a Tcl/Expect script.
This leaves any console output from the VME in
a permanent archive for later examination.
Pete Jemian
UNICAT
Using a terminal server to catch boot messages bickley
Prev: Re: Using a terminal server to catch boot messages Jim Thomas
Next: Re: Using a terminal server to catch boot messages ROBERT F SMYTHE
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Using a terminal server to catch boot messages john sinclair
