1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Using a terminal server to catch boot messages
To: Jim Thomas <[email protected]>
Cc: [email protected], [email protected]
Date: Tue, 30 Oct 2001 11:34:02 +0900
Jim Thomas wrote:
> >>>>> "Matthew" == bickley  <[email protected]> writes:
>  Matthew> I have a vague recollection that some labs have used a
>  Matthew> terminal server to record the boot messages generated by an
>  Matthew> IOC as it boots.  Is there some standard way for doing this,
>  Matthew> or is it completely dependent on the choice of server?  I
>  Matthew> would like to hear what choices other EPICS sites have made.
> We have ours hooked to terminal servers, but have an hpterm/xterm with
> logging turned on and have a "reverse telnet" (on Annexen) connection open
> in the terminal window.  So we let the terminal window on the unix side do
> the logging.
> Jim
We use similar approach.
We use Cisco 2500 and DEC server 900TM as a terminal server in our system.
A console port of IOC is connected to one of serial port on these
terminal servers.
Each  serial port have ether IP address (Cisco) or port number (DEC). So that
we can directly telnet to the console port.
We open a xterminal window for each IOC console port and xterminal
program stores
received data into a log file. We have a Python script to open these
xterminal windows with proper setting with mouse clicks.
These log files are fairly useful to identify the cause of trouble on IOC.
Noboru Yamamoto
KEKB control group
KEK, JAPAN
Re: Using a terminal server to catch boot messages Brian McAllister
Using a terminal server to catch boot messages bickley
Re: Using a terminal server to catch boot messages Jim Thomas
Prev: Re: Using a terminal server to catch boot messages ROBERT F SMYTHE
Next: CA error Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Using a terminal server to catch boot messages Jim Thomas
Next: Re: Using a terminal server to catch boot messages Brian McAllister
