Geoff,
> CAC: unexpected select fail: 851971=S_iosLib_INVALID_FILE_DESCRIPTOR.
This message occurs under EPICS R3.13 (and also probably on earlier
releases). The cause is one thread's shutting down a TCP circuit
while another thread is watching the TCP circuit's file descriptor
with select(). There are no portable mechanism for waking up a thread
waiting in select() other than to synthesize a message over a file
descriptor or to close() one of the file descriptors that select()
is watching. I chose the latter, but this does result in error
status being returned from select(). Since this error can in certain
instances (not this one) indicate a software failure I chose not to
suppress it.
In my experience the above message occurs very rarely, and it is benign,
but it could be selectively suppressed if it becomes sufficiently
annoying.
In EPICS R3.14 this message will not occur because I have removed
from the CA client library all calls to select() in favor of a 100%
thread scheduled design. This appears to be a reasonable choice
given the ubiquitous support for threads in modern operating systems.
Jeff
> I'm running a CA client on IOC A accessing records on a IOC B. After
> performing a ca_clear_channel on all the channels on IOC A connected to
> the IOC B I receive this error:
> From what I understand about CA it appears the fd on IOC A which
> handles the connection to IOC B has been released prematurely.
> I found the errors source in src/ca/bsd_depen.c but am uncertain as to
> how the select bits are set.
> Any insights? Thanks
> Geoff
- CA error Geoff Savage
Linux hosted GNU cross compiler for vxWorks Jeff Hill
<2001>
2025
2026
<2001>
2025
2026
