1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: SSCAN record - changing SDIS from a stringout
To: [email protected]
Date: Thu, 01 Nov 2001 13:19:02 +0100
I am trying to change the value of SDIS in a sscan record from a
stringout and when I process the stringout (for example by writing a new
value to its VAL field from ca)  I get the error message
filename="../recGbl.c" line number=87
Illegal Database Request Type PV: myscan.SDIS error detected in routine:
dbPut - database
 request type is 0
I can change the value in SDIS directly from channel access, and I can
change other fields such as T1PV from a stringout.
SSCAN is VERS 4.12
Epics is 3.13.2
# works
record(stringout,"mystringoutC") {
        field(OUT,"myscan.T1PV")
# does not work
record(stringout,"mystringoutD") {
        field(OUT,"myscan.SDIS")
record(sscan,"myscan") {
What am I doing wrong ?
Steve
Re: SSCAN record - changing SDIS from a stringout Bob Dalesio
Re: SSCAN record - changing SDIS from a stringout Marty Kraimer
Prev: Re: drvTS/NTP issues? Noboru Yamamoto
Next: Re: SSCAN record - changing SDIS from a stringout Bob Dalesio
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: drvTS/NTP issues? Brian McAllister
