1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS Meeting Agenda after ICALEPCS Dec. 3&4
To: [email protected]
Date: Wed, 07 Nov 2001 11:29:06 -0700
Please check the agenda for your name, title, times and let
me know if I have you giving a talk that you do not expect
to be giving, if you need more (or less) time. We do not
closely enforce times, so please consider that it takes
about 2 minutes per slide to present and leave some time for
questions. (Herb, I think that there are two talks with your
name that we need to discuss.) Any other issues, please
bring to my attention. I am hoping to explore the need and
ability to manipulate arrays. If there are any other
digitizer talks or array manipulation in database talks,
please let me know.
THanks,
Bob
Monday Morning:
Status
 9:00   Diamond Update &#8211; Daresbury &#8211; Mark Heron
 9:15   KEKB Status &#8211; Tadahiko Katoh
 9:30   Jaeri-KEKB Joint Project &#8211; Kazuro Furukawa
 9:45   SNS vacuum and resonance control &#8211; LANL
&#8211; Pilar Marroquin
10:00   Conventional Facilities from Vendor @ SNS &#8211;
John Munro
10:15   D0 &#8211; setting up for a run condition &#8211;
Fritz Bartlett
10:30   Break
11:00   LEDA experiences &#8211; LANL &#8211; Deb Kerstiens
11:15   ISAC Interlock system &#8211; Triumf &#8211; Rolf
Keitel
Technology
11:30   Naming conventions &#8211; Dave Gurd
11:45   SNS Application Development Environment - Ernest
Williams
12:00   LANSCE IOC based knobs &#8211; LANL &#8211; Eric
Bjorklund
12:15   Stream Device Driver &#8211; Dirk Zimoch
12:30	  Lunch
 2:00   IPAC for VME 64X &#8211; Mark Heron
 2:15   PIDs in EPICS through PLCs &#8211; Herb Strong
 2:30   LANL - etherIP driver Kay Kasemir
 2:45   DirectNet for MPF &#8211; Andrew Johnson
 3:00   PLC programming interface issues &#8211; Herb Strong
or Bob Dalesio
 3:30   Break
 4:00-6:00  timing workshop &#8211; Timo Korhonen chairman
Tuesday Morning
EPICS Tools
 9:00   BESSY - using OO &#8211; Ralph Lange
 9:15   D0 &#8211; record/device support extensions &#8211;
Fritz Bartlett
 9:30   Joerger Digitizer &#8211; Marty Kraimer?
10:00   Archiver Update &#8211; Thomas Birke
10:15   Archving into Oracle &#8211; LeeAnn Yasukawa
10:30   Break
11:00   Archiver - Matt Bickley for Chris Larrieu
11:15   X-Y Plot - Joan Sage/Pam Gurd
11:30   EDM talk - John Sinclair?
12:00   VDCT - PSI/SLI &#8211; Matej
12:15   Relational DB &#8211; Kay Kasemir
12:30   lunch
 2:00   ORACLE extracted RDB for D0 &#8211; Fritz Barlett
 2:15   Relational DB to generate EPICS DB &#8211; ISAC
&#8211; Rolf Keitel
 2:30   NameServer Update - Joan Sage
 2:45   D0 &#8211; significant event system &#8211; pushed
&#8211; Fritz Bartlett
EPICS Base &#8211;
 3:00   ActiveX Server &#8211; Kay Kasemir
 3:15   Conversion of Gemini to 3.13.4 &#8211; Obs. Sciences
- Andy Foster
 3:30  Coffee and break
 4:00  3.13 - CA Client Synch Data Layer &#8211; LANL
&#8211; Peregrine McGehee
 4:15  3.14 &#8211; Marty Kraimer
 4:30  3.15 - Abstract Data Object &#8211; Jeff Hill / Ralph
Lange
 4:45  3.15 - Link changes &#8211; Andrew Johnson
Bob Dalesio
[email protected]
410 557 0297 Maryland
505 667 3414 Los Alamos
505 699 1632 Cell Phone
505 667 6087 Our Secretary (Judy)
Prev: Re: Using a terminal server to catch boot messages john sinclair
Next: Re: Using a terminal server to catch boot messages briegel
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VxWorks on Linux Ralph . Lange
Next: Time Stamps in Channel Access Vitaliy Ziskin
