1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Using a terminal server to catch boot messages
To: [email protected]
Cc: [email protected]
Date: Wed, 7 Nov 2001 13:39:41 -0600
We use optimation's 4 port rtu and a 8/4 point relay output module which grounds
an in-house board on the P1 connector to provide a sysfail (does not cycle
power).
www.optimate.com:  base is $149, PS $15, relay module $53/$42.
The base also includes an RS232 port which I use to monitor vxWorks booting etc.
The RS232 port is limited to a 40 char buffer and must be polled at 30 Hz (9600
baud) in order to not miss characters.  There is an additional 2 port module
which can be added to the configuration.  We have also used this connection to
control an RS232 interface for a MUX card.
The significant advantage to this solution besides cost, is the extra modules
which can be added to the base which include ADCs and counters for environmental
monitoring.  Although I haven't peruaded anyone to amplify the signal(TTL) from a
chipmuck appropriate for the counter, I believe it would be an excellent solution
for radiation monitoring.  I've written a reasonable vxworks library which allows
for module interrogation so 4 port and 8 port modules can be combined into one 12
port module located in any available slot.
The I/O is via UDP/IP for simple data query/answer for the specified module.
Each module has an ID and the configuration can be retrieved.
The downside to this solution is the lack of TTL I/O, most implementations is
geared around industrial controls for switch control.
Just thought you might want to know about this solution, I'm not pushing
anything.
--charlie briegel, Fermilab Controls
From:	SMTP%"[email protected]"  "john sinclair"    7-NOV-2001
09:18:38.98
CC:	[email protected]
Subj:	Re: Using a terminal server to catch boot messages
Date: Wed, 07 Nov 2001 10:15:43 -0500 (EST)
In-reply-to: <Pine.GSO.4.10.10111061348270.1160-100000@mahina>
X-Sender: [email protected]
To: Nick Rees <[email protected]>
Message-id: <[email protected]>
MIME-version: 1.0
Content-type: TEXT/PLAIN; charset=US-ASCII
We use another device to accomplish the same objectives. Its a small unit
made by Rabbit Semiconductor. We used their development kit to build a
single connection telnet server and also added a relay for remote power
cycles. The SNS guys put together a packaging design that incorporates a
powere supply, rabbit board, relay, and receptacle on a din rail. The
rabbit board sells for about $150. I don't recall the prices of the other
components. We would gladly provide our software.
Using this device we can observe VxWorks boot messages and perform a
remote power cycle of the IOC.
This is a very nice product. The development kit comes with a number of
example applications. In half a day I was talking to the board from a
telnet client and a web browser (the telnet server and http server are
different applications; I could do one or the other).
John Sinclair
[email protected]
Oak Ridge National Lab
865-576-6362   865-574-1268 (fax)
On Tue, 6 Nov 2001, Nick Rees wrote:
> All,
> Just because it hasn't really been mentioned in this thread, and specific
> products may be of interest, we use remote console switches for this. The
> advantage over a terminal server is that it buffers the console output so
> you can look at recent activity, without resorting to disk files. The
> price is pretty comparable.
> Our current favorite is the CMS series from Western Telematic
> (www.wti.com). They allow multiple telnet sessions so you can still have
> all your xterms running, if you want. However, we have found that it is
> useful to have up to date firmware. $1300 for a 16 port system.
> WTI also do remote power switches - the ones you telnet into and type
> 'reboot ioc1' and it very graciously interrupts the 110 volt supply from
> ioc1 for 5 seconds or so. Also useful to have. $600 for 8 separately
> switchable plugs and a total of 30 amps AC.
> So, maybe a crass advert for WTI, but we find them useful since driving
> two hours to the summit just to reboot an ioc is a bit boring.
> Cheers,
> Nick Rees
> Joint Astronomy Centre               Ph:       +1 (808) 961-3756
> 660 N. Aohoku Place                  Fax:      +1 (808) 961-6516
> Hilo, HI.  96720                     Internet: [email protected]
Prev: EPICS Meeting Agenda after ICALEPCS Dec. 3&4 Bob Dalesio
Next: Time Stamps in Channel Access Vitaliy Ziskin
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Fwd: Re: Using a terminal server to catch boot messages Pete R. Jemian
Next: CA error Geoff Savage
