devMbboDirectCamac.c in dev/camacDev directory uses val field of its
record structure
when writing data to CAMAC module as show below:
cfsa(pcio->f, pcio->ext, &(pmbbodirect->val), &q);
The VAL field of mbboDIrect record is defined as:
field(VAL,DBF_USHORT)
while the function cfsa() has a prototype:
void cfsa (int f, int ext, int *dat, int *q);
The convert() function in mbboDirectRecord.c apply bit shift to the VAL
field and is called
just before writeValue() function is called in a process routine.
static void convert(pmbboDirect)
struct mbboDirectRecord *pmbboDirect;
/* convert val to rval */
pmbboDirect->rval = (unsigned long)(pmbboDirect->val);
if(pmbboDirect->shft>0)
pmbboDirect->rval <<= pmbboDirect->shft;
return;
So, I think a call of cfsa in devMbboDirectCamac.c could be:
cfsa(pcio->f, pcio->ext, &(pmbbodirect->rval), &q);.
Or is there any good reason to use current code?
Thank you for your comments/opinions in advance,
Noboru Yamamoto
KEKB control group
KEK, JAPAN
Re: bad UDP messages Noboru Yamamoto
Help about compile CDEV shen guobao
<2001>
2025
2026
RE: VxWorks on Linux Mark Rivers
<2001>
2025
2026
