1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: bad UDP messages
To: Geoff Savage <[email protected]>
Cc: [email protected]
Date: Tue, 13 Nov 2001 08:58:37 +0900
Geoff Savage wrote:
Here is an error message about bad UDP messages. We have seen this from two different IOCs over the weekend.
CAC: post_msg(): Corrupt cmd in UDP msg b
../iocinf.c: bad UDP msg from d0olctl50.fnal.gov:5064
Could this be caused by low memory on the IOCs? Each were running around 80-90% of memory capacity of 16MB.
Thanks
Geoff
We occasionally encounter this message on our IOCs.
1) This message, as pointed by Andrew, one of our terminal server responds to the CA search UDP
message at port 5064 and sends a NON-epics reply to the IOC which send out the CA search UDP message.
Although we have several terminal servers of same type, only one of them causes this symptom.
2) Usually, it indicates there is unresolved channel connection on this IOC. So we have check channel
connection status on this IOC.
3) I believe the program output this message has memory leak. So if you leave this message long enough, this would cause low memory situation, according to my experience.
Noboru Yamamoto
KEKB control group
KEK, JAPAN
RE: bad UDP messages Jeff Hill
bad UDP messages Geoff Savage
Prev: Re: et_wish Andrew Johnson
Next: mbboDirectCamac device support routine Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: bad UDP messages Andrew Johnson
Next: RE: bad UDP messages Jeff Hill
