Hi everybody,
I work with Epics R3.13.1 for PPC (MVME2306). I installed the second Ethernet
interface board (TPMC880). Since the driver delivered with the board was
developed under Tornado 2.0, I switched also to Tornado 2.0, vxWorks 5.4
(previously I worked under Tornado 1.0.1, vxWorks 5.3). I've made all the
necessary changes in vxWorks image to add the second interface as "dc"
unit 1 (as it was recommended by the board developers).
I changed the default port number for CA by
'putenv("EPICS_CA_SERVER_PORT=6025")' shell command before the EPICS
initialization.
Just for testing I downloaded a database consisting of the only waveform
record. The EPICS initialization didn't finish properly. I had the following
messages after iocInit:
> iocInit
> ### @(#)EPICS IOC CORE
> ### @(#)Version R3.13.1..0 $$Date: 1999/11/09 09:47:55 $$
> Starting iocInit
> CAC: net intf flags fetch for failed
> value = 0 = 0x0
> iocInit: All initialization complete
> data access
> Exception current instruction address: 0x0018e7f4
> Machine Status Register: 0x0000b030
> Data Access Register: 0xcc576950
> Condition Register: 0x22000042
> Data storage interrupt Register: 0x40000000
> Task: 0x19ed0a8 "CA online"
> filename="../taskwd.c" line number=175
> task 19ed0a8 CA online suspended
Then in some while I got:
> 0x1bbd0e8 (tNetTask): arptnew failed on 83a970bd
I didn't attach still the second interface.
I rebooted the PPC using unchanged vxWorks image. But with the same
result. What could be the cause of such behaviour?
Thank you in advance for any advice or help,
V.Korobov
- RE: CA online suspended diring EPICS initialization. Jeff Hill
Can EPICS be used in Tokamak? Happy
Where can I find the caMath? guobao shen
<2001>
2025
2026
<2001>
2025
2026
