1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA online suspended diring EPICS initialization.
To: "Vladis Korobov" <[email protected]>, <[email protected]>
Date: Thu, 6 Dec 2001 10:02:38 -0700
Vladis,
You will need to move up to EPICS R3.13.5 to use Tornado II.
Tornado II has a new IP kernel. The network interface query
interface was not backwards compatible and so changes were
required in CA. EPICS R3.13.5 will work with either
Tornado II or Tornado I depending on which version it was built
against. You will need to completely rebuild EPICS base.
Jeff
> -----Original Message-----
> From: Vladis Korobov [mailto:[email protected]]
> Sent: Wednesday, November 28, 2001 4:31 AM
> To: [email protected]
> Subject: CA online suspended diring EPICS initialization.
> Hi everybody,
> I work with Epics R3.13.1 for PPC (MVME2306). I installed the second Ethernet
> interface board (TPMC880). Since the driver delivered with the board was
> developed under Tornado 2.0, I switched also to Tornado 2.0, vxWorks 5.4
> (previously I worked under Tornado 1.0.1, vxWorks 5.3). I've made all the
> necessary changes in vxWorks image to add the second interface as "dc"
> unit 1 (as it was recommended by the board developers).
> I changed the default port number for CA by
> 'putenv("EPICS_CA_SERVER_PORT=6025")' shell command before the EPICS
> initialization.
> Just for testing I downloaded a database consisting of the only waveform
> record. The EPICS initialization didn't finish properly. I had the following
> messages after iocInit:
> > iocInit
> > ###  @(#)EPICS IOC CORE
> > ###  @(#)Version R3.13.1..0 $$Date: 1999/11/09 09:47:55 $$
> > Starting iocInit
> > CAC: net intf flags fetch for  failed
> > value = 0 = 0x0
> > iocInit: All initialization complete
> > data access
> > Exception current instruction address: 0x0018e7f4
> > Machine Status Register: 0x0000b030
> > Data Access Register: 0xcc576950
> > Condition Register: 0x22000042
> > Data storage interrupt Register: 0x40000000
> > Task: 0x19ed0a8 "CA online"
> > filename="../taskwd.c" line number=175
> > task 19ed0a8 CA online suspended
> Then in some while I got:
> > 0x1bbd0e8 (tNetTask): arptnew failed on 83a970bd
> I didn't attach still the second interface.
> I rebooted the PPC using unchanged vxWorks image. But with the same
> result. What could be the cause of such behaviour?
> Thank you in advance for any advice or help,
> V.Korobov
CA online suspended diring EPICS initialization. Vladis Korobov
Prev: Channel Archiver on HP-UX 11.0 Noboru Yamamoto
Next: Re: Channel Archiver on HP-UX 11.0 Thomas Birke
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CA online suspended diring EPICS initialization. Vladis Korobov
Next: Where can I find the caMath? guobao shen
