Hi all,
In the astronomy world FITS format is common, and uses timestamps
that start the same but are only the first 19 characters.
If a suggestion like Peregrine's gets implemented, can this
have an optional cutoff at the integer seconds?
At the JAC we currently have this implemented 2 ways, the older
being in code, the newer one with a stringin in bc635 time card
device support (Nick may correct me if I got this completely upside
down).
Aloha,
Maren
Peregrine M. McGehee wrote:
> At the Sloan Digital Sky Survey we are moving the timestamp
> formats for all observing software (both EPICS and non-EPICS)
> to that of ISO 8601 (http://www.w3.org/TR/NOTE-datetime).
> I propose adding an option TS_TEXT_ISO to base/src/libCom/tsSubr.c:tsStampToText(). Lines beginning with
> an asterisk are copied from the R3.13.5 source code.
> * The required size of the caller's text buffer depends on the type
> * of conversion being requested. The conversion types, buffer sizes,
> * and conversion formats are:
> * TS_TEXT_MONDDYYYY 32 Mon dd, yyyy hh:mm:ss.nano-secs
> * TS_TEXT_MMDDYY 28 mm/dd/yy hh:mm:ss.nano-secs
> TS_TEXT_ISO 36 YYYY-MM-DDThh:mm:ss.nano-secsTZD
> (eg 1997-07-16T19:20:30.123456789+01:00)
> where:
> YYYY = four-digit year
> MM = two-digit month (01=January, etc.)
> DD = two-digit day of month (01 through 31)
> hh = two digits of hour (00 through 23) (am/pm NOT allowed)
> mm = two digits of minute (00 through 59)
> ss = two digits of second (00 through 59)
> nano-secs = digits representing a decimal fraction of a second
> TZD = time zone designator (Z or +hh:mm or -hh:mm)
> * For any of the formats, the fractional part of the time (represented
> * as `nano-secs' above) is variable length. If the usec and nsec part
> * of the time are both zero, only milli-seconds will be printed; or
> * else if the nsec part is zero, only milli-seconds and micro-seconds
> * will be printed.
> Aloha,
> Peregrine
> Peregrine M. McGehee [email protected] (505) 667-3273
> Sloan Digital Sky Survey / Spallation Neutron Source
> MS H820, Los Alamos National Laboratory, Los Alamos, NM 87545
- Re: ISO time format for tsStampToText Peregrine M. McGehee
- ISO time format for tsStampToText Peregrine M. McGehee
<2001>
2025
2026
<2001>
2025
2026
