1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ISO time format for tsStampToText
To: [email protected]
Date: Thu, 06 Dec 2001 13:06:22 -0700
At the Sloan Digital Sky Survey we are moving the timestamp
formats for all observing software (both EPICS and non-EPICS)
to that of ISO 8601 (http://www.w3.org/TR/NOTE-datetime).
I propose adding an option TS_TEXT_ISO to base/src/libCom/tsSubr.c:tsStampToText(). Lines beginning with
an asterisk are copied from the R3.13.5 source code.
* 	The required size of the caller's text buffer depends on the type
*       of conversion being requested.  The conversion types, buffer sizes,
*       and conversion formats are:
*       TS_TEXT_MONDDYYYY  32   Mon dd, yyyy hh:mm:ss.nano-secs
*       TS_TEXT_MMDDYY     28   mm/dd/yy hh:mm:ss.nano-secs
	TS_TEXT_ISO	   36   YYYY-MM-DDThh:mm:ss.nano-secsTZD
	(eg 1997-07-16T19:20:30.123456789+01:00)
where:
     YYYY = four-digit year
     MM   = two-digit month (01=January, etc.)
     DD   = two-digit day of month (01 through 31)
     hh   = two digits of hour (00 through 23) (am/pm NOT allowed)
     mm   = two digits of minute (00 through 59)
     ss   = two digits of second (00 through 59)
     nano-secs    =  digits representing a decimal fraction of a second
     TZD  = time zone designator (Z or +hh:mm or -hh:mm)
* 	For any of the formats, the fractional part of the time (represented
*       as `nano-secs' above) is variable length.  If the usec and nsec part
*       of the time are both zero, only milli-seconds will be printed; or
*       else if the nsec part is zero, only milli-seconds and micro-seconds
*       will be printed.
Aloha,
	Peregrine
Peregrine M. McGehee	[email protected]	(505) 667-3273
Sloan Digital Sky Survey / Spallation Neutron Source
MS H820, Los Alamos National Laboratory, Los Alamos, NM 87545
Re: ISO time format for tsStampToText Maren Purves
Prev: Re: Channel Archiver on HP-UX 11.0 Thomas Birke
Next: Re: ISO time format for tsStampToText Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Channel Archiver on HP-UX 11.0 Noboru Yamamoto
