1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel Archiver on HP-UX 11.0
To: Thomas Birke <[email protected]>
Date: Fri, 07 Dec 2001 16:50:08 +0900
Thanks Thomas and Kay,
Now Channel Archiver is running on our HP-UX 11 machine.
What I have done is
1) add the following lines in CONFIG.Host.hppa8k (I use hppa8k in stead
of hp700) in base/config.
ARCH_DEP_CFLAGS += -D_HPUX_SOURCE -DHP_UX
ARCH_DEP_CFLAGS += -D_POSIX_C_SOURCE=199506L
ARCH_DEP_CXXFLAGS += -D_HPUX_SOURCE -DHP_UX
ARCH_DEP_CXXFLAGS += -D_POSIX_C_SOURCE=199506L
2) and also add similar lines in Make.pth and Makefile.Host files in Channel Archiver directories appropriately.
3) rebuild everything in base and Channel Archiver.
3') For gcc2.95.3, I needed to put
#include <new>
when we got the error message:
/usr/local/lib/gcc-lib/hppa2.0w-hp-hpux11.00/2.95.3/include/new:28:`operator new' takes type `size_t' as first parameter
from the compiler. With gcc2.95.3, the code:
#include <list>
or
#include <list>
#include <new>
create the message mentioned above. However,
#include <new>
#include <list>
seems work OK.
I use: EPICS_R3.13.5, Channel Archiver 1.6.1 gcc 2.95.3 HP-UX 11.0
for this compilation.
Thanks again,
Noboru
KEKB control group
KEK, JAPAN
Thomas Birke wrote:
At 09:09 PM 12/6/2001 +0900, Noboru Yamamoto wrote:
I'm trying to compile Channel Archiver on HP-UX 11.0 using gcc2.95.3
without much success.
Is there anyone who can run Channel Archiver on HP-UX 11 with its
pthread library ?
HP-UX 11 is still an issue...
I also didn't get it to work on HP-UX 11 - neither with gcc2.95.3 nor with aCC.
Currently I have no time (not even an HP-UX 11 machine at hand) to get into this problem?
But it's on my list...
Thomas
Re: Channel Archiver on HP-UX 11.0 Thomas Birke
Prev: Re: ISO time format for tsStampToText Peregrine M. McGehee
Next: Help about Middleware guobao shen
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Channel Archiver on HP-UX 11.0 Thomas Birke
Next: ISO time format for tsStampToText Peregrine M. McGehee
