1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mbbiRecord undefined state
To: Bernd Schoeneburg <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Mon, 07 Jan 2002 14:13:38 -0600
I agree with your conclusion. I will make your suggested change so that it will
be in the next 3.13 and 3.14 releases.
Marty Kraimer
Bernd Schoeneburg wrote:
> Hi all,
> I have just discovered something that seems to me to be a bug in the
> mbbi record support routines. When status-values are defined but the
> current raw value doesn't fit any of them, the value will become 65535
> and the UDF bit will be set. In the alarm routine UDF causes an invalid
> severity error which can not be overwritten by something else. This
> leads to the situation that the setting of the UNSV field is without any
> effect.
> I propose to delete all existing manipulations of UDF in process() and
> insert only one "..->udf = FALSE" when the raw value is successfully
> read. This is the place after "if (status == 0)". This works fine for
> me. Any comments?
> Bernd
> Bernd Schoeneburg
> Group MKS-2
> DESY, Germany
mbbiRecord undefined state Bernd Schoeneburg
Prev: Re: mbbiRecord undefined state Marty Kraimer
Next: VXI driver support John Faucett
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: iocsh for Epics314b1 on win32 Marcel Grunder
