1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Newbie question: example Application
To: "'John Dobbins'" <[email protected]>
Cc: "'EPICS-tech-talk'" <[email protected]>
Date: Fri, 11 Jan 2002 15:03:17 -0700
John,
You might find that it is easier to add the following to your startup
script (before iocInit is called):
putenv("EPICS_CA_ADDR_LIST = 128.84.44.84 192.168.213.148")
Alternatively, you might try quotes around the IP addresses in the
resource.def as follows:
EPICS_CA_ADDR_LIST DBF_STRING  "128.84.44.84 192.168.213.148"
I seem to vaguely recall that this also works.
Jeff
> I have just installed EPICS software (3.13.5) and built the example
> application. The iocCore runs and I can communicate with it via the
> console. The client, caExample, runs but is unable to communicate with
the
> iocCore.
> On the host in response to "caExample aiExample" I get the message:
> CA.Client.Diagnostic..............................................
>      Message: "User specified timeout on IO operation expired"
>      Severity: "Warning" Context: "ca_pend_io failure"
>      Source File: ../caExample.c Line Number: 20
>      Message: "The request was ignored because the specified channel
is
> disconnected"
>      Severity: "Error" Context: "ca_get failure"
>      Source File: ../caExample.c Line Number: 21
> The iocCore is on a protected subnet and I am hypothesizing that this
may
> be why the client is unable to communicate with it. I tried to follow
> instructions in the Channel Access Reference Manual, section 1.3.2,
> Configuring CA for Multiple Subnets. However when I add the line
> EPICS_CA_ADDR_LIST DBF_STRING  128.84.44.84 192.168.213.148
> to resource.def  ( used by iocInt )  I get an error during iocInit:
> Starting iocInit
> filename="../iocInit.c" line number=599
> Missing resource data type field for resource=128.84.44.84 in
> file=resource.def
> value = 0 = 0x0
> Any advice would be appreciated.
> John Dobbins
> Cornell University - Lab of Nuclear Studies
> tele:    607-255-5740
> fax:     607-254-4552
Newbie question: example Application John Dobbins
Prev: Newbie question: example Application John Dobbins
Next: channel access reboot behavior Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
