1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Newbie question: example Application
To: [email protected]
Date: Fri, 11 Jan 2002 14:54:47 -0500
Dear All,
I have just installed EPICS software (3.13.5) and built the example application. The iocCore runs and I can communicate with it via the console. The client, caExample, runs but is unable to communicate with the iocCore.
On the host in response to "caExample aiExample" I get the message:
CA.Client.Diagnostic..............................................
Message: "User specified timeout on IO operation expired"
Severity: "Warning" Context: "ca_pend_io failure"
Source File: ../caExample.c Line Number: 20
Message: "The request was ignored because the specified channel is disconnected"
Severity: "Error" Context: "ca_get failure"
Source File: ../caExample.c Line Number: 21
The iocCore is on a protected subnet and I am hypothesizing that this may be why the client is unable to communicate with it. I tried to follow instructions in the Channel Access Reference Manual, section 1.3.2, Configuring CA for Multiple Subnets. However when I add the line
EPICS_CA_ADDR_LIST DBF_STRING 128.84.44.84 192.168.213.148
to resource.def ( used by iocInt ) I get an error during iocInit:
Starting iocInit
filename="../iocInit.c" line number=599
Missing resource data type field for resource=128.84.44.84 in file=resource.def
value = 0 = 0x0
Any advice would be appreciated.
John Dobbins
Cornell University - Lab of Nuclear Studies
tele:    607-255-5740
fax:     607-254-4552
RE: Newbie question: example Application Jeff Hill
Prev: RE: Unix process & file system & disk space monitoring GOURNAY Jean-François DAPNIA
Next: RE: Newbie question: example Application Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
