1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VXI shared memory transfer
To: John Faucett <[email protected]>, [email protected]
Date: Mon, 28 Jan 2002 10:54:46 -0500
John Faucett wrote:
> I am writing device support for a message-based VXI module that
> supports two modes of data transfer:
> (1) Via a message, specifically through the SCPI "TRACE #" command.
> This is too slow -- 1000 words takes 30 seconds.
> (2) Via shared memory, using the SCPI "SMEM" command.  The
> documentation shows an example using the VISA viMoveAsync routine,
> but I believe there is no VISA library for EPICS.
> Can anyone give me pointers on writing a routine using shared memory
> transfer?  The VXI slot-0 controller is a hkbaja60 module.
Does your VXI module support Fast Data Channel (FDC protocol) ?
It uses local memory or remote memory to transfer data, which is
very fast.  I used FDC protocol for a tektronix VXI based scope
to trasfer the waveform, and achieved 16-30KB/s at single cycles.
Cheers,
S. Kate Feng
Brookhaven National Lab.
National Synchrotron Light Source
Bldg. 725D
Upton, New York  11973-5000
Email: [email protected]
VXI shared memory transfer John Faucett
Prev: VME Crate Bridges Eric Bjorklund
Next: Re: VME Crate Bridges Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: VXI shared memory transfer John Faucett
Next: RE: VXI shared memory transfer Jeff Hill
