1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA client library and Connection handler
To: <[email protected]>
Date: Wed, 30 Jan 2002 19:54:19 -0500 (EST)
Hello All,
I am relatively new to epics so I apologize if my question seems poorly
informed.
I am trying to monitor the connection of channels using
ca_change_connection_event from the client library and am having
difficulty getting it to work. I would like to do a group poll
(synchronous or asynchronously) of my channels at a certain frequency and
would like make sure that my channels are connected before I do this.  I
though I could just install a connection handler like in the example:
    for (pCurrent = pFirst; pCurrent != NULL; pCurrent = pCurrent->next){
       status=ca_change_connection_event(pCurrent->chan,
	                                myHandler);
       SEVCHK(status, "ca_change_connection_event:
			couldn't change handler");
and then have something like:
while(1){
	ca_pend_event(POLL); //
	myGroupPoll();
	nanosleep(fiveseconds,NULL);
and then have my handler either block or remove from my list those
channels that have been disconnected. Instead when I run it and disconnect
a channel there is a pause of about 5 seconds and then a segmentation
violation( although I think handler does get called).  The same thing
happens if I remove myGroupPoll().
In addition I seem the same behavior running the example code given at:
http://mesa53.lanl.gov/lansce8/Epics/ca/client/caX5Ftutor-6.html#HEADING6-0
Any help would be greatly appreciated.
Adam DeGrush
Re: CA client library and Connection handler Brian McAllister
RE: CA client library and Connection handler Jeff Hill
Prev: Re: Iocsh with win32. Bad soft-record support? mooney
Next: 2'nd Iocsh with win32. Bad soft-record support? kuner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CA client library and Connection handler Brian McAllister
