1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: 2'nd Iocsh with win32. Bad soft-record support?
To: EPICS tech-talk <[email protected]>
Date: Thu, 31 Jan 2002 07:27:42 +0100
Thank you Pete Jemian and Tim Mooney,
but unfortunately the problem is still the same, if I call dbLoadRecords
in the proper way. There is no record support:
        C:\project\epics\base-3.14.beta1.Apps>example
        epics> dbLoadDatabase "dbd/example.dbd"
        epics> dbLoadRecords "db/dbExample1.db", "user=HORST"
        Error   Last token ")"
        input line: record(ai, "HORST:aiExample")
           in: file db/dbExample1.db line 1
        db_parse returned -1
        epics> dbAllocRecord(ai) record_size =0
        filename="..\dbLexRoutines.c" line number=869
        Record support not found new record instance error
        epics> iocInit
        ###  @(#)EPICS IOC CORE built on Jan 25 2002
        ###  @(#)Version R3.14.0.beta.1 $R3-14-0-beta-1$ $2001/09/13
19:13:12$
        Starting iocInit
        iocInit record support for ai not found
        iocInit record support for ao not found
Is it possible to do something wrong when building the base? I suppose
the linker uses only the functions the program refers to, but record
support functions are called by pointers and not by name, so it may be
they are NOT linked in the example.exe. May this happen?
Is there anybody in the epics-world who make this example run with a
Windows-PC?
Gruessle
      Bernhard Kuner
----------------- [email protected] -----------------
Re: 2'nd Iocsh with win32. Bad soft-record support? kuner
Prev: CA client library and Connection handler Adam Jon DeGrush
Next: Epics 3.13.5 supporting Windows 2000 ? Goetz Pfeiffer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CA client library and Connection handler Brian McAllister
Next: Re: 2'nd Iocsh with win32. Bad soft-record support? kuner
