1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics 3.13.5 supporting Windows 2000 ?
To: Goetz Pfeiffer <[email protected]>
Cc: [email protected]
Date: Thu, 31 Jan 2002 08:39:56 -0600
We see the same error on NT4 workstations.  Everything works though.
Geoff
Goetz Pfeiffer wrote:
> Hi,
> I've recently tested my EPICS-Perl library (Pezca) under Windows 2000.
> My new version uses EPICS 3.13.5, I use the Microsoft Visual C 6.0
> compiler.
> When I start my test-program which is similar to executing a "caget"
> I see the following error message:
> "Unexpected UDP failure WIN32 Socket Library Error 10054"
> The actual reading of the record works, but the error message is printed
> each time I try to read a record, sometimes the message is printed
> twice, before the value can be read.
> I have two questions:
> Does anyone know this error message ?
> Has anyone sucessfully tested EPICS 3.13.5 or previous versions with
> Windows 2000 ?
> Many thanks
>   Götz Pfeiffer        ([email protected]
>                         http://www-csr.bessy.de/~pfeiffer)
Epics 3.13.5 supporting Windows 2000 ? Goetz Pfeiffer
Prev: Epics 3.13.5 supporting Windows 2000 ? Goetz Pfeiffer
Next: Re: CA client library and Connection handler Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Epics 3.13.5 supporting Windows 2000 ? matthias muntwiler
