1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics 3.13.5 supporting Windows 2000 ?
To: [email protected]
Date: Thu, 31 Jan 2002 17:18:22 +0100
i can reproduce your error message on my win2k system with a "caget"
command at the command prompt whenever "caRepeater" is not running.
(check it by launching and stopping it manually.)
caRepeater.exe is started automatically by the ca.dll - probably with
ca_task_initialize. in order to suppress the message in your code,
waiting until caRepeater is running may help. i've never got the error
with my own code which uses direct ca.dll calls - for what reason ever.
besides, i'd like to emphasize that channel access runs very well on my
win2k system. i write a client application for a photoemission
spectroscopy experiment that runs under EPICS. the code is written in
borland delphi (object pascal), and it wasn't a big deal to access
ca.dll functions directly.
yours
matthias muntwiler
Goetz Pfeiffer wrote:
> When I start my test-program which is similar to executing a "caget"
> I see the following error message:
> "Unexpected UDP failure WIN32 Socket Library Error 10054"
> The actual reading of the record works, but the error message is printed
> each time I try to read a record, sometimes the message is printed
> twice, before the value can be read.
> I have two questions:
> Does anyone know this error message ?
> Has anyone sucessfully tested EPICS 3.13.5 or previous versions with
> Windows 2000 ?
  matthias muntwiler
  surface physics, university of zurich
  swiss light source (sls), paul-scherrer-institut, villigen
  mailto:[email protected]
  http://www.physik.unizh.ch/groups/grouposterwalder/
RE: "Unexpected UDP failure WIN32 Socket Library Error 10054" Jeff Hill
Epics 3.13.5 supporting Windows 2000 ? Goetz Pfeiffer
Prev: et_wish, threadInit and osiThread.h Benjamin Sailer
Next: Re: CA client library and Connection handler Adam Jon DeGrush
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Epics 3.13.5 supporting Windows 2000 ? Geoff Savage
Next: RE: "Unexpected UDP failure WIN32 Socket Library Error 10054" Jeff Hill
