Thanks Brian for the help.
On Thu, 31 Jan 2002, Brian McAllister wrote:
> >>> On 1/30/2002 at 19:54:19 EST, Adam Jon DeGrush wrote:
> > I am trying to monitor the connection of channels using
> > ca_change_connection_event from the client library and am having
> > difficulty getting it to work. I would like to do a group poll
> > (synchronous or asynchronously) of my channels at a certain frequency
> > and would like make sure that my channels are connected before I do
> > this.
> First, are you "monitoring" your channels (using ca_add_event()) or are you
> using ca_get() in your poll function ?
I was using ca_sg_array_get() for polling in this case. I wasn't doing any
monitoring of channels here but I was planning on installing monitors
using ca_add_event() in the future. Why? Is there problems with this?
> In any case, there is a field in the CHID that holds the status of the
> connection, and a macro defined in cadef.h for accessing it (ca_state()).
> The possible values are cs_never_conn, cs_prev_conn, cs_conn, cs_closed.
> > I though I could just install a connection handler like in the
> > example:
> > for (pCurrent = pFirst; pCurrent != NULL; pCurrent = pCurrent->next){
> > status=ca_change_connection_event(pCurrent->chan, myHandler);
> > SEVCHK(status, "ca_change_connection_event:
> > couldn't change handler");
> ca_change_connection_event() is normally used to replace an existing
> connection handler, which would have been initially associated with the
> channel by specifying it in the ca_search_and_connect() call used to open
> the channel.
ca_search_and_connect() was used at initialization with it returning
cs_conn before replacing it with ca_change_connection_event().
> > and then have something like:
> > while(1){
> > ca_pend_event(POLL); //
> > myGroupPoll();
> > nanosleep(fiveseconds,NULL);
> > and then have my handler either block or remove from my list those
> > channels that have been disconnected. Instead when I run it and
> > disconnect a channel there is a pause of about 5 seconds and then a
> > segmentation violation( although I think handler does get called).
> (The "pause" is probably the time it takes for your system to write out a
> "core" file.)
> What do you mean by "disconnect a channel" ? Your connection handler has
> been invoked *because* the channel has changed connection state. Either it
> has re-connected, or it is already disconnected.
I was speaking loosely. By disconnecting I meant I my ioc was rebooting.
> > The same thing happens if I remove myGroupPoll().
> Which clearly implies that the action which causes the seg fault is in your
> connection handler.
I still see a seg fault if I replace myHandler with NULL or I just have
myHandler printing out the name of the channel via
ca_name(connect_args.chid). The name is printed correctly before aborting.
> If all you are doing in the connection handler is flagging when a channel
> is available or not, the CA library does that for you. You only really
> need the connection handler if you need special handling (initialization,
> message generation, cleanup, etc) when the connection changes state.
> Otherwise, just test the state before you try to access the value.
Thanks for this info, you're right this is probably the better way to do
this.
Adam DeGrush
- Re: CA client library and Connection handler Brian McAllister
Re: Epics 3.13.5 supporting Windows 2000 ? matthias muntwiler
Re: et_wish, threadInit and osiThread.h Marty Kraimer
<2002>
2025
2026
<2002>
2025
2026
