1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS iocLog file size limitation
To: Kevin Tsubota <[email protected]>
Cc: [email protected]
Date: Thu, 21 Mar 2002 11:27:24 -0500
>>> On 3/20/2002 at 18:07:11 -1000, Kevin Tsubota wrote:
  > We just recently upgraded to our host to Solaris 8 and noticed that our
  > EPICS iocLog files are limited to 1MB with the data being over written
  > from the top.  We have a number of other files that are greater than
  > 1MB being written by non-EPICS systems in the same directory.  Prior to
  > this we were running SunOS 4.1.4 hosts and have iocLogs > 1MB.
The limit is in iocLogServer, and is controlled by the environment variable
EPICS_IOC_LOG_FILE_LIMIT, which normally defaults to 1MB.  You can either
change the default (CONFIG_SITE_ENV in $EPICS_BASE/config is the right
place for that) or you can set it in the environment before you start the
logServer.
Brian McAllister                    Controls Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
Re: EPICS iocLog file size limitation Robert Willson
EPICS iocLog file size limitation Kevin Tsubota
Prev: Re: EPICS iocLog file size limitation Deb Kerstiens
Next: Re: EPICS iocLog file size limitation Robert Willson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS iocLog file size limitation Kevin Tsubota
