1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS iocLog file size limitation
To: [email protected]
Date: Thu, 21 Mar 2002 11:50:58 -0500 (EST)
I have a rather odd problem with the logfile.  It seems that I cannot
change where the logfile goes, even if I change the name in resource.def.
Stranger still, if I move (mv) the file to a different directory, EPICS
continues to write to that file, instead of creating a new one in the old
directory.  I do not understand this behavior.
Robert
> The limit is in iocLogServer, and is controlled by the environment variable
> EPICS_IOC_LOG_FILE_LIMIT, which normally defaults to 1MB.  You can either
> change the default (CONFIG_SITE_ENV in $EPICS_BASE/config is the right
> place for that) or you can set it in the environment before you start the
> logServer.
> Brian McAllister                    Controls Programmer/Beam Physicist
> [email protected]                        MIT-Bates Linear Accelerator
Re: EPICS iocLog file size limitation Andrew Johnson
Re: EPICS iocLog file size limitation Brian McAllister
Prev: Re: EPICS iocLog file size limitation Brian McAllister
Next: Re: EPICS iocLog file size limitation Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
