Robert Willson wrote:
> I have a rather odd problem with the logfile. It seems that I cannot
> change where the logfile goes, even if I change the name in resource.def.
The location is not under the control of the IOC - any resource.def
setting for the log filename will be ignored. You have to change that
setting for the log server (using environment variables before you start
it) if you want to move the file, and if you want multiple files I think
you have to run multiple servers on different port numbers.
- Andrew
Perfection is reached, not when there is no longer anything to add,
but when there is no longer anything to take away.
- Antoine de Saint-Exupery
- Re: EPICS iocLog file size limitation Robert Willson
Re: EPICS iocLog file size limitation Deb Kerstiens
<2002>
2025
2026
<2002>
2025
2026
