Korhonen Timo wrote:
Hello all,
I was implementing some calculations with calcout records and
faced the following problem: with certain input values, the
result from the formula is NAN (not a number.) However, there
is no indication from the record itself that something is wrong.
(medm can display an INF but does not react to NAN.)
I would like to be able to raise an alarm (INVALID) if the result
from the calculation is NAN (at least, and maybe also for INF).
A quick try to modify the return from calcPerform
(libCom/calc/calPerform.c)so that
instead of (line 514)
return(0);
I made a simple check:
return(isnan(*presult));
and that seemed to give the effect that I wanted.
Does this look like a reasonable thing to do?
Timo
This sounds like a good solution.
A couple of details.
I do not find isnan defined in our version of vxWorks. Instead I find isNan.
How did you get calcPerform to build on vxWorks and also load without undefined
symbols?
Thus for 3.13 the following builds
mercury% cvs diff -c calcPerform.c
Index: calcPerform.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/Attic/calcPerform.c,v
retrieving revision 1.31.6.1
diff -c -r1.31.6.1 calcPerform.c
*** calcPerform.c 2000/08/09 13:51:08 1.31.6.1
--- calcPerform.c 2002/03/26 15:57:17
*** 102,107 ****
--- 102,109 ----
#ifdef vxWorks
#include <vxWorks.h>
+ #include <private/mathP.h> /* For isNan*/
+ #define isnan isNan
#endif
#include <stdlib.h>
*** 514,520 ****
*presult = *pstacktop;
else
return(-1);
! return(0);
--- 516,522 ----
else
return(-1);
! return(isnan(*presult));
Then on solaris I get
"../calcPerform.c", line 519: warning: implicitly declaring function to return
int: isnan()
I dont know why because calcPerform includes math.h.
For 3.14 I just use epicsMath which defines epicsIsNAN
Does anyone have any comments?
Marty Kraimer
- Re: calc/calcout and NAN Korhonen Timo
- calc/calcout and NAN Korhonen Timo
<2002>
2025
2026
<2002>
2025
2026
