1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: calc/calcout and NAN
To: [email protected]
Date: Tue, 26 Mar 2002 16:15:35 +0100
Hello all,
I was implementing some calculations with calcout records and
faced the following problem: with certain input values, the
result from the formula is NAN (not a number.) However, there
is no indication from the record itself that something is wrong.
(medm can display an INF but does not react to NAN.)
I would like to be able to raise an alarm (INVALID) if the result
from the calculation is NAN (at least, and maybe also for INF).
A quick try to modify the return from calcPerform (libCom/calc/calPerform.c)so that
instead of (line 514)
return(0);
I made a simple check:
return(isnan(*presult));
and that seemed to give the effect that I wanted.
Does this look like a reasonable thing to do?
Timo
Timo Korhonen PSI (Paul Scherrer Institut), SLS
CH-5232 Villigen PSI
tel + 41- 56 3103262 fax + 41 - 56 310 3151
e-mail: [email protected]
Re: calc/calcout and NAN Marty Kraimer
Prev: Re: seq 1.9.4 Marty Kraimer
Next: Re: calc/calcout and NAN Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: seq 1.9.4 Ned Arnold
