Till,
I think that we already eradicated that one along the way to the next
R3.14 release. See attached. Nevertheless, thanks for the heads up.
Jeff
Revision : 1.23
Date : 2002/1/15 20:2:45
Author : 'jhill'
State : 'Exp'
Lines : +2 -2
Description :
fixed to preserve 8 byte alignment
cvs diff -r 1.23 -r 1.22 tsFreeList.h (in directory
D:\users\hill\epicsDvl\epics\base\src\libCom\cxxTemplates\)
Index: tsFreeList.h
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/cxxTemplates/tsFreeL
ist.h,v
retrieving revision 1.23
retrieving revision 1.22
diff -r1.23 -r1.22
2c2
< /* $Id: tsFreeList.h,v 1.23 2002/01/15 20:02:45 jhill Exp $
> /* $Id: tsFreeList.h,v 1.22 2002/01/15 16:46:11 jhill Exp $
75d74
< char pad[ sizeof ( T ) ];
76a76
*****CVS exited normally with code 1*****
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Till Straumann
> Sent: Thursday, April 04, 2002 9:04 PM
> To: [email protected]
> Cc: [email protected]
> Subject: ca_test bus error on solaris-sparc-gnu + fix
> Hi all.
> We got a SIGBUS (due to an alignment violation)
> running ca_test (and other apps)
> EPICS: 3.14.0.beta1
> system: solaris-sparc-gnu
> compiler: egcs-2.91.66
> I found that
> void *
> tsFreeList<T,N,DEBUG_LEVEL>::allocate(size_t)
> may return improperly aligned memory:
> Because 'items' are declared
> union {
> tsFreeListItem<T,...> *pNext;
> char pad[sizeof(T)];
> the compiler only makes sure 'items' fulfill
> the alignment requirements of pNext.
> However, 'items' may need stricter alignment
> (which goes unnoticed because the 'item' pointer
> is later cast to (void*)): e.g. it may contain a double
> which on sparc needs to be 8byte aligned...
> The proposed fix is to put the 'items' into a
> chunk first, so they get the chunk's alignment.
> Unfortunately, this fix breaks binary compatibility
> - everything needs to be rebuilt.
> Regards,
> -- Till
- Re: ca_test bus error on solaris-sparc-gnu + fix Till Straumann
- ca_test bus error on solaris-sparc-gnu + fix Till Straumann
Re: AO Record: New Drive Limit Mode? Andrew Johnson
waveform record question Pedro Gigoux
<2002>
2025
2026
<2002>
2025
2026
