1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ca_test bus error on solaris-sparc-gnu + fix
To: [email protected]
Cc: [email protected]
Date: Tue, 09 Apr 2002 17:35:17 -0700
Jeff Hill wrote:
> Till,
> I think that we already eradicated that one along the way to the next
> R3.14 release. See attached. Nevertheless, thanks for the heads up.
> Jeff
Jeff.
>From the attached diff it is not obvious to me what your fix is
- would you mind giving me a hint, please?
I am not sure if 8byte alignment is enough
(e.g. optimized code on PPC/altivec may need 16 bytes.)
IMHO, it would be best to preserve the alignment
returned by malloc()
-- Till
> Revision : 1.23
> Date : 2002/1/15 20:2:45
> Author : 'jhill'
> State : 'Exp'
> Lines : +2 -2
> Description :
> fixed to preserve 8 byte alignment
> cvs diff -r 1.23 -r 1.22 tsFreeList.h (in directory
> D:\users\hill\epicsDvl\epics\base\src\libCom\cxxTemplates\)
> Index: tsFreeList.h
> RCS file:
> /net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/cxxTemplates/tsFreeL
> ist.h,v
> retrieving revision 1.23
> retrieving revision 1.22
> diff -r1.23 -r1.22
> 2c2
> < /*  $Id: tsFreeList.h,v 1.23 2002/01/15 20:02:45 jhill Exp $
> > /*  $Id: tsFreeList.h,v 1.22 2002/01/15 16:46:11 jhill Exp $
> 75d74
> <     char pad[ sizeof ( T ) ];
> 76a76
> *****CVS exited normally with code 1*****
> > -----Original Message-----
> > From: [email protected]
> > [mailto:[email protected]] On Behalf Of Till Straumann
> > Sent: Thursday, April 04, 2002 9:04 PM
> > Subject: ca_test bus error on solaris-sparc-gnu + fix
> > Hi all.
> > We got a SIGBUS (due to an alignment violation)
> > running ca_test (and other apps)
> > EPICS:      3.14.0.beta1
> > system:    solaris-sparc-gnu
> > compiler: egcs-2.91.66
> > I found that
> > void *
> > tsFreeList<T,N,DEBUG_LEVEL>::allocate(size_t)
> > may return improperly aligned memory:
> > Because 'items' are declared
> > union {
> >    tsFreeListItem<T,...> *pNext;
> >    char                           pad[sizeof(T)];
> > the compiler only makes sure 'items' fulfill
> > the alignment requirements of pNext.
> > However, 'items' may need stricter alignment
> > (which goes unnoticed because the 'item' pointer
> > is later cast to (void*)): e.g. it may contain a double
> > which on sparc needs to be 8byte aligned...
> > The proposed fix is to put the 'items' into a
> > chunk first, so they get the chunk's alignment.
> > Unfortunately, this fix breaks binary compatibility
> > - everything needs to be rebuilt.
> > Regards,
> > -- Till
Re: ca_test bus error on solaris-sparc-gnu + fix Andrew Johnson
RE: ca_test bus error on solaris-sparc-gnu + fix Jeff Hill
Prev: waveform record question Pedro Gigoux
Next: Re: ca_test bus error on solaris-sparc-gnu + fix Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: ca_test bus error on solaris-sparc-gnu + fix Jeff Hill
