1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ca_test bus error on solaris-sparc-gnu + fix
To: "'Till Straumann'" <[email protected]>
Cc: <[email protected]>
Date: Wed, 10 Apr 2002 09:22:27 -0600
Till,
After closer inspection, I see that there were two entries in the CVS
log related to this issue. Attached is the one that applies to
preserving the alignment returned by ::new(). The change reported in my
previous message will have no impact because it is only rearranging
fields in a union. Sorry about the confusion. I added "diff -c" to my
.cvsrc file and I now receive context diffs from CVS.
Revision : 1.22
Date : 2002/1/15 16:46:11
Author : 'jhill'
State : 'Exp'
Lines : +2 -2
Description :
fixed to preserve 8 byte alignment
cvs diff -r 1.22 -r 1.21 tsFreeList.h (in directory
D:\users\hill\epicsDvl\epics\base\src\libCom\cxxTemplates\)
Index: tsFreeList.h
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/cxxTemplates/tsFreeL
ist.h,v
retrieving revision 1.22
retrieving revision 1.21
diff -c -r1.22 -r1.21
*** tsFreeList.h	2002/01/15 16:46:11	1.22
--- tsFreeList.h	2001/12/14 00:36:25	1.21
*** 1,5 ****
! /*  $Id: tsFreeList.h,v 1.22 2002/01/15 16:46:11 jhill Exp $
   *                    L O S  A L A M O S
   *              Los Alamos National Laboratory
--- 1,5 ----
! /*  $Id: tsFreeList.h,v 1.21 2001/12/14 00:36:25 jhill Exp $
   *                    L O S  A L A M O S
*** 78,85 ****
  template < class T, unsigned N = 0x400, unsigned DEBUG_LEVEL = 0u >
  struct tsFreeListChunk {
-     tsFreeListItem < T, DEBUG_LEVEL > items [N];
      tsFreeListChunk < T, N, DEBUG_LEVEL > *pNext;
--- 78,85 ----
+     tsFreeListItem < T, DEBUG_LEVEL > items [N];
*****CVS exited normally with code 1*****
Jeff
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Till Straumann
> Sent: Tuesday, April 09, 2002 6:35 PM
> To: [email protected]
> Cc: [email protected]
> Subject: Re: ca_test bus error on solaris-sparc-gnu + fix
> Jeff Hill wrote:
> > Till,
> > I think that we already eradicated that one along the way to the
next
> > R3.14 release. See attached. Nevertheless, thanks for the heads up.
> > Jeff
> Jeff.
> >From the attached diff it is not obvious to me what your fix is
> - would you mind giving me a hint, please?
> I am not sure if 8byte alignment is enough
> (e.g. optimized code on PPC/altivec may need 16 bytes.)
> IMHO, it would be best to preserve the alignment
> returned by malloc()
> -- Till
> > Revision : 1.23
> > Date : 2002/1/15 20:2:45
> > Author : 'jhill'
> > State : 'Exp'
> > Lines : +2 -2
> > Description :
> > cvs diff -r 1.23 -r 1.22 tsFreeList.h (in directory
> > Index: tsFreeList.h
> > RCS file:
> > ist.h,v
> > retrieving revision 1.23
> > diff -r1.23 -r1.22
> > 2c2
> > < /*  $Id: tsFreeList.h,v 1.23 2002/01/15 20:02:45 jhill Exp $
> > 75d74
> > <     char pad[ sizeof ( T ) ];
> > 76a76
Straumann
> > > Sent: Thursday, April 04, 2002 9:04 PM
> > > Subject: ca_test bus error on solaris-sparc-gnu + fix
> > > Hi all.
> > > We got a SIGBUS (due to an alignment violation)
> > > running ca_test (and other apps)
> > > EPICS:      3.14.0.beta1
> > > system:    solaris-sparc-gnu
> > > compiler: egcs-2.91.66
> > > I found that
> > > void *
> > > tsFreeList<T,N,DEBUG_LEVEL>::allocate(size_t)
> > > may return improperly aligned memory:
> > > Because 'items' are declared
> > > union {
> > >    tsFreeListItem<T,...> *pNext;
> > >    char                           pad[sizeof(T)];
> > > the compiler only makes sure 'items' fulfill
> > > the alignment requirements of pNext.
> > > However, 'items' may need stricter alignment
> > > (which goes unnoticed because the 'item' pointer
> > > is later cast to (void*)): e.g. it may contain a double
> > > which on sparc needs to be 8byte aligned...
> > > The proposed fix is to put the 'items' into a
> > > chunk first, so they get the chunk's alignment.
> > > Unfortunately, this fix breaks binary compatibility
> > > - everything needs to be rebuilt.
> > > Regards,
> > > -- Till
Re: ca_test bus error on solaris-sparc-gnu + fix Till Straumann
Prev: Re: waveform record question Marty Kraimer
Next: NAN and INF Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ca_test bus error on solaris-sparc-gnu + fix Andrew Johnson
Next: Re: ca_test bus error on solaris-sparc-gnu + fix Till Straumann
