1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: NAN and INF
To: [email protected]
Date: Wed, 10 Apr 2002 10:54:45 -0500
Recently Timo Korhonen mentioned a problem caused by the calcoutRecord passing on a NaN value to other records. Recently we saw something that we suspect was caused by something generating either a NAN or an INF. The latest 3.13 known problems describes a fix for the calcOutRecord (and calcPerform) that fixes the NAN problem. We are still not handling the INF problem.
Let me first give a brief discussion of NAN and INF. The IEEE floating point standard defines the concept of NAN (not a number) and INF (infinity). For each the exponent portion of the number has a unique bit pattern (normally all 1s), A NAN has a nonzero significand and an INF has a zero significand. A NAN is generated for invalid operations like 0/0. An INF is generated for exponent overflow.
Part of the solution to the NAN problem Timo discovered was to make the following change to calcPerform
diff -r1.31.6.1 calcPerform.c
104a105,106
> #include        <private/mathP.h> /* For isNan*/
> #define isnan isNan
517c519
< return(0);
> return((isnan(*presult) ? -1 : 0));
Thus a error is returned in calcPerform calculates a NAN. It looks like a solution for both NAN and INF is to change the return to
return(((isnan(*presult)||isinf(*presult)) ? -1 : 0));
PROBLEM:
This assumes that isnan and isinf are provided on all platforms that epics supports.
Both isnan and isinf are defined as part of the ISO C standard from 1999.
They are supported on redhat 7.2 linux. They are not supported on vxWorks 5.4 or on solaris 8. Not suprising considering the 1999 date.
The following are diffs that allow me to compile 3.13 calcPerform on solaris, vxWorks, and linux redhat 7.2
> #include        <stddef.h>
119a115,128
> #ifdef vxWorks
> #include <vxWorks.h>
> #define isnan isNan
> #define isinf isInf
> #endif
> #ifdef SOLARIS
> #define __EXTENSIONS__
> #include <limits.h>
> #define isinf(D) \
> ((fabs((D))>DBL_MAX || fabs((D))<DBL_MIN) ? 1 : 0)
> #endif
519c528
<       return(0);
This is REALLY ugly. Worse what about HPUX, WINxx, and earlier releases of Solaris and Linux?
What to do??????
Marty Kraimer
RE: NAN and INF Jeff Hill
Prev: RE: ca_test bus error on solaris-sparc-gnu + fix Jeff Hill
Next: RE: NAN and INF Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: waveform record question Marty Kraimer
