At 12:16 PM 4/11/2002, Andrew Johnson wrote:
>There are also two undocumented routines mentioned in
>shellLib.h called shellLoginInstall() and shellLogoutInstall() that you
>can use to install your own routines to be called when someon does
>{dis}connect. I use that here at APS to output the long DOE "you must be
>authorized to use this machine" message before prompting for the username
>and password.
A documented alternative to that might be:
loginStringSet("login (you must be authorized to use this machine): ")
-Kay
>STATUS apsLoginPrompt(char *userName) {
> puts(doe_msg);
> taskDelay(1); /* Give the above message a chance to
>flush */
> return loginPrompt(userName);
>In config/all/usrConfig.c the following line was added immediately after
>the call to loginInit():
>shellLoginInstall (apsLoginPrompt, NULL); /* install security program */
- Re: Capturing a telnet connection event Andrew Johnson
- Capturing a telnet connection event J. Frederick Bartlett ([email protected])
<2002>
2025
2026
<2002>
2025
2026
