1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: strange behaviour of dbLoadtemplate
To: EPICS tech talk <[email protected]>
Date: Thu, 18 Apr 2002 19:16:22 +0200
dear EPICS gurus
(if somebody prefers to make the experience rather than reading
do first  dbLoadtemplate test1.subs
second    dbLoadtemplate test2.subs
the short files are at the end of this longer mail)
recentely I found a very strange behaviour of dbLoadtemplate.
For a special device the result of dbLoadtemplate had to look like:
  record(mbbo,"test:CON-FUNC") {
     field(ZSTR,""CURR:DC"")
It is important that there are 2 qoutation marks just one after
the other at the beginning and at the end. I found no other solution
than to have a template file with
    field(ZRST,"$(qm)CURR:DC$(qm)")
and in the substitution file I put
  qm = '\"'
This worked perfectely, the whole substituion file test1.subs is
at the end of this mail:
I got the request to add an other record, an easy job, I thought,
but ....
test2.subs is at the end of the mail, too
and the result of dbLoadtemplate:
in words: it did not substitute qm with " but with the
rest of the file!
(I put ">" to show that this is the output)
> field(ZRST, ""'}
>{ NAME = X09LA-KCUR2
> GPNR = 11
> qm = '"CURR:DC"'}>
> GPNR = 11
> qm = '"")
> field(ONVL, "1")
After playing around I found no other solution than to have
2 dbLoadtemplates, each one loding one record.
Thanks for any hints
Werner
************** files ************
test1.subs
>file test.template {
>{ NAME    = X09LA-KCUR
>  ADDR    = L38940
>  GPNR    = 10
>  qm      = '\"'}
test2.subs
>{ NAME    = X09LA-KCUR
>  GPNR    = 10
>  qm	   = '\"'}
>  GPNR    = 11
>  qm	   = '\"'}
test.template
>record(mbbo,"$(NAME):CON-FUNC") {
>    field(ZRVL,"0")
>    field(ONVL,"1")
>    field(ONST,"$(qm)VOLT:DC$(qm)")
Dr. Werner Portmann, SLS computing and controls
Paul Scherrer Institut, CH-5232 Villigen PSI
tel + 41- 56 3104061 fax + 41 - 56 310 4413
e-mail: [email protected] http://people.web.psi.ch/portmann/
Prev: Re: Help about epics Monitor using CORBA Christopher Larrieu
Next: drvAscii - termintor strategy Ian A Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: drvAscii - termintor strategy Peregrine M. McGehee
Next: Re: strange behaviour of dbLoadtemplate Luedeke Andreas WSLA/209
