the problem can be solved by replacing the single quotes in the substitution file with double
quotes.
Is there any "lex" expert listening who knows why?
Andreas
PS: is it a desired feature, that escaped characters are only handled in substitution files but not
in templates?
Dr. Andreas Luedeke, PSI/SLS, phone: +41-56-310-4002 fax: -4413
mailto:[email protected], http://people.web.psi.ch/luedeke
> dear EPICS gurus
> (if somebody prefers to make the experience rather than reading
> do first dbLoadtemplate test1.subs
> second dbLoadtemplate test2.subs
> the short files are at the end of this longer mail)
> recentely I found a very strange behaviour of dbLoadtemplate.
> For a special device the result of dbLoadtemplate had to look like:
> record(mbbo,"test:CON-FUNC") {
> field(ZSTR,""CURR:DC"")
> It is important that there are 2 qoutation marks just one after
> the other at the beginning and at the end. I found no other solution
> than to have a template file with
> field(ZRST,"$(qm)CURR:DC$(qm)")
> and in the substitution file I put
> qm = '\"'
> This worked perfectely, the whole substituion file test1.subs is
> at the end of this mail:
> I got the request to add an other record, an easy job, I thought,
> but ....
> test2.subs is at the end of the mail, too
> and the result of dbLoadtemplate:
> in words: it did not substitute qm with " but with the
> rest of the file!
> (I put ">" to show that this is the output)
> field(ZRST, ""'}
> >{ NAME = X09LA-KCUR2
> > GPNR = 11
> > qm = '"CURR:DC"'}>
> > GPNR = 11
> > qm = '"")
> field(ONVL, "1")
> After playing around I found no other solution than to have
> 2 dbLoadtemplates, each one loding one record.
> Thanks for any hints
> Werner
> ************** files ************
> test1.subs
> >file test.template {
> >{ NAME = X09LA-KCUR
> > ADDR = L38940
> > GPNR = 10
> > qm = '\"'}
> test2.subs
> >{ NAME = X09LA-KCUR
> > GPNR = 10
> > qm = '\"'}
> > GPNR = 11
> > qm = '\"'}
> test.template
> >record(mbbo,"$(NAME):CON-FUNC") {
> > field(ZRVL,"0")
> > field(ONVL,"1")
> > field(ONST,"$(qm)VOLT:DC$(qm)")
> Dr. Werner Portmann, SLS computing and controls
> Paul Scherrer Institut, CH-5232 Villigen PSI
> tel + 41- 56 3104061 fax + 41 - 56 310 4413
> e-mail:
> [email protected] http://people.web.psi.ch/portmann/
- Re: strange behaviour of dbLoadtemplate Marty Kraimer
Re: drvAscii - termintor strategy Allan Honey
RE: drvAscii - terminator strategy Porter, Rodney
<2002>
2025
2026
strange behaviour of dbLoadtemplate Werner Portmann
<2002>
2025
2026
