1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: AO: Drive Limit Mode
To: [email protected]
Date: Wed, 24 Apr 2002 08:33:17 -0500
Another thought related to this topic.
The EPICS "motor" record currently uses the "Reject" model if a request is
made to move past a soft limit.  However, it does set a field, .LVIO (Limit
Violation) if a move request is made that would violate the soft limits
(.LLM, .HLM), so there is an "alarm" visible on operator interfaces (but I
think it does not really raise alarms, those are set by checking against the
standard .LOW, .HIGH, etc. fields).  Generally I think that "Reject" is the
desired behavior, because the invalid request is likely due to operator
error.
However, just last week I had to modify the SNL program for our
monochromator in order to implement the "Clamp" behavior, moving to the soft
limit if the calculated position for a motor was beyond the soft limit.  It
would also be nice if the motor record could be switched between the two
modes (Reject or Clamp) that are being discussed for the ao record.  My
point is that this is a more general problem than "ao" and it would be nice
to agree to a solution that can be slowly propogated to other records.
Mark Rivers
Prev: Re: AO: Drive Limit Mode Bob Dalesio
Next: Re: NAN and [email protected] Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: AO: Drive Limit Mode Andreas Luedeke
Next: Problem with iocsh prompt Rarback, Harvey
