1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AO: Drive Limit Mode
To: Kay-Uwe Kasemir <[email protected]>
Cc: [email protected]
Date: Thu, 25 Apr 2002 17:29:09 +0200
Hi Kay,
another suggestion for the (withdrawn) DRLM solution:
The clamp mode should rather use the PVAL field instead of the OVAL field.
If you have a periodically scanned "ao_reject" record, due to the OROC field slowly ramping
to reach the final value VAL. Now a user writes a new value that is out of the allowed drive range.
   * If the VAL field is now set to OVAL, the record would stop at the current output value, a value
     that was never set by any user or application.
   * If the VAL field is set to PVAL, the record would continue to drive to the last accepted value.
I think the latter is maybe the preferred "reject" behaviour.
Cheers
Andreas
Kay-Uwe Kasemir wrote:
> >I am not happy with the proposed solution.
> Oops.
> I stand corrected and withdraw the proposed DRLM field.
> >That doesn't mean that we shouldn't do something about the problem.
> >See below for alternative solutions that reuse or rather extend the already existing
> >features....
> What followed included several important thoughts, thought
> not code. Is anybody out there not 110% busy but would have
> time to look into this?
> Meanwhile, whoever needs the described behavior and feels
> that a drive limit mode field fixes it for now:
> You can always add a new record, a copy of the AO record that includes
> the previously emailed diffs, without changing EPICS base.
> Thanks,
> -Kay
Dr. Andreas Luedeke, PSI/SLS, phone: +41-56-310-4002 fax: -4413
mailto:[email protected], http://people.web.psi.ch/luedeke
AO: Drive Limit Mode Kay-Uwe Kasemir
Re: AO: Drive Limit Mode Kay-Uwe Kasemir
Prev: Re: AO: Drive Limit Mode Kay-Uwe Kasemir
Next: 3.14 questions Carl Lionberger
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: AO: Drive Limit Mode rivers
