>>> On 5/27/2002 at 16:29:19 EDT, Vitaliy Ziskin wrote:
> I try do the following :
> caput channelName.VAL -1
> and get the following:
> caput: invalid option -- 1
> Old : channelName.VAL 0.00
> What's going on?
You're on GNU/Linux.
caput uses getopt() to parse the command line. GNU getopt() has different
default behavior from other implementations.
>From the man page:
By default, getopt() permutes the contents of argv as it
scans, so that eventually all the non-options are at the
end.
Which means that a negative argument will be parsed as a command option,
which caput does not expect.
If the first character of optstring is `+' or the
environment variable POSIXLY_CORRECT is set, then option
processing stops as soon as a non-option argument is
encountered.
The work-around is to put
setenv POSIXLY_CORRECT
in your shell startup.
Brian McAllister Controls Programmer/Beam Physicist
[email protected] MIT-Bates Linear Accelerator
(617) 253-9537 Middleton, MA
- Re: error in caput ("caputting negative numbers") Bill Cruise
- error in caput ("caputting negative numbers") Vitaliy Ziskin
Device Support for RAMdisk Jane Richards
EPICS Base 3.13.6 Caveat Ralph . Lange
<2002>
2025
2026
<2002>
2025
2026
