Brian McAllister wrote:
> >>> On 5/27/2002 at 16:29:19 EDT, Vitaliy Ziskin wrote:
> > I try do the following :
> > caput channelName.VAL -1
> > and get the following:
> > caput: invalid option -- 1
> > Old : channelName.VAL 0.00
> > What's going on?
> You're on GNU/Linux.
> The work-around is to put
> setenv POSIXLY_CORRECT
> in your shell startup.
Another work-around is to put the negative value in quotes,
with a space between the opening quote and the minus sign,
like so:
caput channelName.VAL " -123"
This keeps unfriendly parsers away from your argument. :-)
William L. Cruise [email protected]
Electronics System Supervisor FAX: 808 885-7288
Canada-France-Hawaii Telescope Voice: 808 885-3121
65-1238 Mamalahoa Highway http://www.cfht.hawaii.edu/~cruise
Kamuela, HI 96743
- Re: error in caput ("caputting negative numbers") Matthieu Bec
- Re: error in caput ("caputting negative numbers") Brian McAllister
Re: EPICS Base 3.13.6 Caveat Tim Mooney
<2002>
2025
2026
<2002>
2025
2026
