1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base 3.13.6 Caveat
To: Tim Mooney <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 29 May 2002 09:06:37 +0200
  Ralph> The effect occurs when the calc/calcout is reading CA input links that
  Ralph> are INVALID either because the CA link hasn't connected or it isn't
  Ralph> granted read access by the source IOC.
  Ralph> ...
  Ralph> after a reboot the first processing often occured before all inputs had
  Ralph> been connected...
  Tim> Yikes!  Initializing a database is hard enough without worrying about
  Tim> links that haven't connected yet.  How about...
  Tim> case INITHOOKafterInterruptAccept :
  Tim> taskDelay(600);			<--<<
  Tim> break;
  Tim> ....in initHooks() ?  Am I right in thinking this would delay processing
  Tim> caused by .PINI=="YES", and allow CA links some more time to connect?
  Tim> You'd still want to do what you've suggested, of course, to defend
  Tim> against links that really are broken.  But .PINI is pretty much useless
  Tim> if it sometimes causes processing before databases that will eventually
  Tim> be sound are ready to go.
Hmmmh.
Well, you are right that it would delay things a bit and _maybe_ allow
some more CA links to connect, but:
 o Since there are _many_ reasons why CA input connects could be late,
   adding a delay would just shift probabilities a bit. Even in our case
   the percentage of switched off power supplies was between 10% and
   100% - depending on the local IOC load, the remote IOC load, the
   network load, how many other CA clients were connecting etc.
 o Actually waiting for the CA inputs to connect could delay the initial
   processing infinitely, which contradicts just a bit too much.
 o When a record has one or more .CPP input links, PINI is meaningless
   anyway. Every connecting CA input link will process the record
   once. (Since you always get one update when a monitor connects.)
 o With the new behaviour the calc/out record will start performing the
   CALC and setting its state to something different from LINK/INVALID
   as soon as all inputs are there. This is definitely the desired
   behaviour.
Even if one could argue that such a change in behaviour is too big for a
bugfix release and the record support should be changed to show the old
behaviour, I'd rather not take any steps in that direction, since it's
the wrong way.
I guess it is really necessary (and time, maybe) to sweep up the
databases and check that results of calc/out records are handling the
INVALID state correctly. We were relying on a wrong behaviour. _Sigh._
Cheers,
Ralph
EPICS Base 3.13.6 Caveat Ralph . Lange
Re: EPICS Base 3.13.6 Caveat Tim Mooney
Prev: Re: error in caput ("caputting negative numbers") Matthieu Bec
Next: EPICS Meeting Spring '02 - Wrap-Up Ralph . Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS Base 3.13.6 Caveat Tim Mooney
