1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: error in caput ("caputting negative numbers")
To: [email protected]
Cc: [email protected]
Date: Wed, 29 May 2002 12:12:24 -0500 (CDT)
>I try do the following :
>caput channelName.VAL -1
>and get the following:
>caput: invalid option -- 1
>Old : channelName.VAL              0.00
I believe your version of caput is out of date. The newer
version of caput will accept the negative value directly.
( The newer version needs to set the environment
variable LD_LIBRARY_PATH on the solaris system. )
For your information, the newer version of caput command
syntax is given below:
kao 49: caput
Usage:  caput [-t] [-s] [-w sec] [--] pv_name  pv_value
This command writes a value or array of values to a channel.
It can also write an array of single values to an array of channels.
        -t   Terse mode, only the successfully put value is returned
        -s   pv_value entered as database defined enumeral string
    -w sec   Wait time, specifies bigger time out, default is 1 second
        -m   this option specified the input value string is
             a comma separated values for a waveform record
   pv_name   requested database process variable name
             (multiple PV names must be seperated by comma no space)
   pv_value  new value to put to IOC
             (multiple PV values must be seperated by comma no space)
  Examples:    caput  pv_name  pv_value
               caput  pv_name1,pv_name2   pv_value1,pv_value2
               caput -m  pv_name  v1,v2,v3,...
kao 50: caput chademoai2 -4
Old : chademoai2                     -3
New : chademoai2                     -4
kao 51:
Prev: EPICS Meeting Spring '02 - Wrap-Up Ralph . Lange
Next: Support for Allen Bradley FlexLogix? Rarback, Harvey
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: error in caput ("caputting negative numbers") Matthieu Bec
Next: Device Support for RAMdisk Jane Richards
